[GRASS-stats] GRASS can't find R packages from personal library on Windows
Helmut Kudrnovsky hellik at web.de
Fri Nov 18 02:39:40 PST 2016
Roger Bivand wrote
>> could you download the files from
>> https://trac.osgeo.org/grass/browser/grass/trunk/mswindows/external/rbatch,
>> copy these to an arbitrary folder e.g. C:\wd\testfolder, open a windows
>> console within this folder and type R in the console, then try your test
>> with  Sys.getenv("R_LIBS_USER") and  .libPaths()?
>> for me it works that the general and private library is found by R.
> OK, looks like this:
> [1] "C:\\Users\\rsb\\Documents/R/win-library/3.3"
>> .libPaths()
> [1] "C:/Users/rsb/Documents/R/win-library/3.3"
> [2] "C:/Program Files/R/R-3.3.2/library"
>> any(match(installed.packages()[,"Package"], "rgrass7"))
> [1] TRUE
> But I don't see any recent revisions in that directory?
it is taken from https://github.com/ggrothendieck/batchfiles by author`s
permission.
so the script works outside a winGRASS session also for you.
but the same script doesn't work inside a winGRASS session. so it's maybe
related to some %HOME% issues as mentioned before.
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5296444.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
