[GRASS-stats] GRASS can't find R packages from personal library on Windows
Helmut Kudrnovsky hellik at web.de
Fri Nov 18 06:17:12 PST 2016
Helmut Kudrnovsky wrote
> both changes should be discussed on the dev ML.
> before such changes are implemented, the workaround to manage this issue
> manually via the control panel should go to the wiki.
> Anna, any suggestions?
just opened a discussion on the dev ML:
https://lists.osgeo.org/pipermail/grass-dev/2016-November/083122.html
best regards
Helmut
View this message in context: http://osgeo-org.1560.x6.nabble.com/GRASS-can-t-find-R-packages-from-personal-library-on-Windows-tp5295771p5296481.html
Sent from the Grass - Stats mailing list archive at Nabble.com.
More information about the grass-stats mailing list
