[GRASS-stats] rgrass7 - SQLite and GML drivers not working for readVECT
Veronica Andreo veroandreo at gmail.com
Tue Oct 10 13:52:36 PDT 2017
Hello Roger,
Sorry I forgot this info. Here, the outputs:
> sessionInfo()
R version 3.4.1 (2017-06-30)
Platform: x86_64-redhat-linux-gnu (64-bit)
Running under: Fedora 26 (Twenty Six)
Matrix products: default
BLAS/LAPACK: /usr/lib64/R/lib/libRblas.so
locale:
 [1] LC_CTYPE=en_US.UTF-8       LC_NUMERIC=C
 [3] LC_TIME=en_US.UTF-8        LC_COLLATE=en_US.UTF-8
 [5] LC_MONETARY=en_US.UTF-8    LC_MESSAGES=en_US.UTF-8
 [7] LC_PAPER=en_US.UTF-8       LC_NAME=C
 [9] LC_ADDRESS=C               LC_TELEPHONE=C
[11] LC_MEASUREMENT=en_US.UTF-8 LC_IDENTIFICATION=C
attached base packages:
[1] stats     graphics  grDevices utils     datasets  methods   base
loaded via a namespace (and not attached):
[1] compiler_3.4.1
> library(rgrass7)
Loading required package: sp
Loading required package: XML
GRASS GIS interface loaded with GRASS version: GRASS 7.3.svn (2017)
and location: nc_spm_08_grass7
> library(rgdal)
rgdal: version: 1.2-13, (SVN revision 686)
 Geospatial Data Abstraction Library extensions to R successfully loaded
 Loaded GDAL runtime: GDAL 2.1.3, released 2017/20/01
 Path to GDAL shared files: /usr/share/gdal
 Loaded PROJ.4 runtime: Rel. 4.9.3, 15 August 2016, [PJ_VERSION: 493]
 Path to PROJ.4 shared files: (autodetected)
 Linking to sp version: 1.2-5
> ogrDrivers()
             name
long_name
1      AeronavFAA                                                 Aeronav
FAA
2      AmigoCloud
AmigoCloud
3          ARCGEN                                           Arc/Info
Generate
4          AVCBin                                    Arc/Info Binary
Coverage
5          AVCE00                               Arc/Info E00 (ASCII)
Coverage
6             BNA                                                   Atlas
BNA
7           Carto
Carto
8        Cloudant                                          Cloudant /
CouchDB
9         CouchDB                                          CouchDB /
GeoCouch
10            CSV                                Comma Separated Value
(.csv)
11            CSW                      OGC CSW (Catalog  Service for the
Web)
12            DGN                                            Microstation
DGN
13            DXF                                                 AutoCAD
DXF
14         EDIGEO                               French EDIGEO exchange
format
15  ElasticSearch                                              Elastic
16 ESRI Shapefile                                              ESRI
Shapefile
17     Geoconcept
Geoconcept
18        GeoJSON
GeoJSON
19       Geomedia                                               Geomedia
.mdb
20         GeoRSS
GeoRSS
21            GFT                                        Google Fusion
Tables
22            GML                             Geography Markup Language
(GML)
23           GPKG
GeoPackage
24       GPSBabel
GPSBabel
25  GPSTrackMaker
GPSTrackMaker
26            GPX
GPX
27            HTF                                Hydrographic Transfer
Vector
28           HTTP                                       HTTP Fetching
Wrapper
29         Idrisi                                        Idrisi Vector
(.vct)
30     Interlis 1                                                  Interlis
1
31     Interlis 2                                                  Interlis
2
32            JML                                                OpenJUMP
JML
33    JP2OpenJPEG                  JPEG-2000 driver based on OpenJPEG
library
34       JPEG2000 JPEG-2000 part 1 (ISO/IEC 15444-1), based on Jasper
library
35            KML                               Keyhole Markup Language
(KML)
36         LIBKML                            Keyhole Markup Language
(LIBKML)
37   MapInfo File                                                MapInfo
File
38         Memory
Memory
39   MSSQLSpatial                       Microsoft SQL Server Spatial
Database
40          MySQL
MySQL
41            NAS                                                 NAS -
ALKIS
42         netCDF                                  Network Common Data
Format
43           ODBC
ODBC
44            ODS        Open Document/ LibreOffice / OpenOffice
Spreadsheet
45       OGR_DODS
OGR_DODS
46        OGR_GMT                                    GMT ASCII Vectors
(.gmt)
47       OGR_OGDI                               OGDI Vectors (VPF, VMAP,
DCW)
48        OGR_PDS                                Planetary Data Systems
TABLE
49       OGR_SDTS
SDTS
50        OGR_VRT                                    VRT - Virtual
Datasource
51        OpenAir
OpenAir
52    OpenFileGDB                                                ESRI
FileGDB
53            OSM                                   OpenStreetMap XML and
PBF
54         PCIDSK                                        PCIDSK Database
File
55            PDF                                              Geospatial
PDF
56         PGDUMP                                         PostgreSQL SQL
dump
57           PGeo                                   ESRI Personal
GeoDatabase
58       PLSCENES                                      Planet Labs Scenes
API
59     PostgreSQL
PostgreSQL/PostGIS
60            REC                                               EPIInfo
.REC
61            S57                                              IHO S-57
(ENC)
62       SEGUKOOA                                        SEG-P1 / UKOOA
P1/90
63           SEGY
SEG-Y
64        Selafin
Selafin
65         SQLite                                         SQLite /
Spatialite
66            SUA             Tim Newport-Peace's Special Use Airspace
Format
67            SVG                                    Scalable Vector
Graphics
68            SXF                                 Storage and eXchange
Format
69          TIGER                                      U.S. Census
TIGER/Line
70        UK .NTF                                                     UK
.NTF
71            VDV                         VDV-451/VDV-452/INTREST Data
Format
72            VFK                        Czech Cadastral Exchange Data
Format
73           Walk
Walk
74           WAsP                                            WAsP .map
format
75            WFS                               OGC WFS (Web Feature
Service)
76            XLS                                             MS Excel
format
77           XLSX                              MS Office Open XML
spreadsheet
78         XPlane                        X-Plane/Flightgear aeronautical
data
   write  copy isVector
1  FALSE FALSE     TRUE
2   TRUE FALSE     TRUE
3  FALSE FALSE     TRUE
4  FALSE FALSE     TRUE
5  FALSE FALSE     TRUE
6   TRUE FALSE     TRUE
7   TRUE FALSE     TRUE
8   TRUE FALSE     TRUE
9   TRUE FALSE     TRUE
10  TRUE FALSE     TRUE
11 FALSE FALSE     TRUE
12  TRUE FALSE     TRUE
13  TRUE FALSE     TRUE
14 FALSE FALSE     TRUE
15  TRUE FALSE     TRUE
16  TRUE FALSE     TRUE
17  TRUE FALSE     TRUE
18  TRUE FALSE     TRUE
19 FALSE FALSE     TRUE
20  TRUE FALSE     TRUE
21  TRUE FALSE     TRUE
22  TRUE FALSE     TRUE
23  TRUE  TRUE     TRUE
24  TRUE FALSE     TRUE
25  TRUE FALSE     TRUE
26  TRUE FALSE     TRUE
27 FALSE FALSE     TRUE
28 FALSE FALSE     TRUE
29 FALSE FALSE     TRUE
30  TRUE FALSE     TRUE
31  TRUE FALSE     TRUE
32  TRUE FALSE     TRUE
33 FALSE  TRUE     TRUE
34 FALSE  TRUE     TRUE
35  TRUE FALSE     TRUE
36  TRUE FALSE     TRUE
37  TRUE FALSE     TRUE
38  TRUE FALSE     TRUE
39  TRUE FALSE     TRUE
40  TRUE FALSE     TRUE
41 FALSE FALSE     TRUE
42  TRUE  TRUE     TRUE
43  TRUE FALSE     TRUE
44  TRUE FALSE     TRUE
45 FALSE FALSE     TRUE
46  TRUE FALSE     TRUE
47 FALSE FALSE     TRUE
48 FALSE FALSE     TRUE
49 FALSE FALSE     TRUE
50 FALSE FALSE     TRUE
51 FALSE FALSE     TRUE
52 FALSE FALSE     TRUE
53 FALSE FALSE     TRUE
54  TRUE FALSE     TRUE
55  TRUE  TRUE     TRUE
56  TRUE FALSE     TRUE
57 FALSE FALSE     TRUE
58 FALSE FALSE     TRUE
59  TRUE FALSE     TRUE
60 FALSE FALSE     TRUE
61  TRUE FALSE     TRUE
62 FALSE FALSE     TRUE
63 FALSE FALSE     TRUE
64  TRUE FALSE     TRUE
65  TRUE FALSE     TRUE
66 FALSE FALSE     TRUE
67 FALSE FALSE     TRUE
68 FALSE FALSE     TRUE
69  TRUE FALSE     TRUE
70 FALSE FALSE     TRUE
71  TRUE FALSE     TRUE
72 FALSE FALSE     TRUE
73 FALSE FALSE     TRUE
74  TRUE FALSE     TRUE
75 FALSE FALSE     TRUE
76 FALSE FALSE     TRUE
77  TRUE FALSE     TRUE
78 FALSE FALSE     TRUE
best,
Vero
2017-10-10 22:36 GMT+02:00 Roger Bivand <Roger.Bivand at nhh.no>:
> Please report sessionInfo() in R, and check the ogrDrivers() list.
> Roger Bivand
> Norwegian School of Economics
> Bergen, Norway
> On Tue, Oct 10, 2017 at 10:03 PM +0200, "Helmut Kudrnovsky" <hellik at web.de
> > wrote:
> >Are SQLite and GML drivers disabled/broken in readVECT?
>> some earlier discussions I remembered:
>> https://lists.osgeo.org/pipermail/grass-stats/2015-July/001561.htmlhttps://lists.osgeo.org/pipermail/grass-stats/2015-July/001562.html
>> [...]https://lists.osgeo.org/pipermail/grass-stats/2015-June/date.html
>> best regards
>> Helmut
>> Sent from: http://osgeo-org.1560.x6.nabble.com/Grass-Stats-f4049448.html
>> grass-stats mailing listgrass-stats at lists.osgeo.orghttps://lists.osgeo.org/mailman/listinfo/grass-stats
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20171010/0bd6c6b4/attachment-0001.html>
More information about the grass-stats mailing list
