[GRASS-stats] rgrass7 - SQLite and GML drivers not working for readVECT
Roger Bivand Roger.Bivand at nhh.no
Tue Oct 10 14:16:19 PDT 2017
And output of v.in.ogr -f? Nothing has changed in rgrass7, I'll check in the morning.
Roger
Roger Bivand
Norwegian School of Economics
Bergen, Norway
Fra: Helmut Kudrnovsky
Sendt: tirsdag 10. oktober, 22.56
Emne: Aw: Re: [GRASS-stats] rgrass7 - SQLite and GML drivers not working for readVECT
Til: Veronica Andreo
Kopi: Roger Bivand, grass-stats at lists.osgeo.org
    Gesendet: Dienstag, 10. Oktober 2017 um 22:52 Uhr Von: "Veronica Andreo" An: "Roger Bivand" Cc: "grass-stats at lists.osgeo.org" , "Helmut Kudrnovsky" Betreff: Re: [GRASS-stats] rgrass7 - SQLite and GML drivers not working for readVECT Hello Roger,  Sorry I forgot this info. Here, the outputs: > sessionInfo() R version 3.4.1 (2017-06-30) Platform: x86_64-redhat-linux-gnu (64-bit) Running under: Fedora 26 (Twenty Six) Matrix products: default BLAS/LAPACK: /usr/lib64/R/lib/libRblas.so locale:  [1] LC_CTYPE=en_US.UTF-8       LC_NUMERIC=C               [3] LC_TIME=en_US.UTF-8        LC_COLLATE=en_US.UTF-8     [5] LC_MONETARY=en_US.UTF-8    LC_MESSAGES=en_US.UTF-8    [7] LC_PAPER=en_US.UTF-8       LC_NAME=C                  [9] LC_ADDRESS=C               LC_TELEPHONE=C            [11] LC_MEASUREMENT=en_US.UTF-8 LC_IDENTIFICATION=C       attached base packages: [1] stats     graphics  grDevices utils     datasets  methods   base     loaded via a namespace (and not attached): [1] compiler_3.4.1 ---- > library(rgrass7) Loading required package: sp Loading required package: XML GRASS GIS interface loaded with GRASS version: GRASS 7.3.svn (2017) and location: nc_spm_08_grass7 > library(rgdal) rgdal: version: 1.2-13, (SVN revision 686)  Geospatial Data Abstraction Library extensions to R successfully loaded  Loaded GDAL runtime: GDAL 2.1.3, released 2017/20/01  Path to GDAL shared files: /usr/share/gdal  Loaded PROJ.4 runtime: Rel. 4.9.3, 15 August 2016, [PJ_VERSION: 493]  Path to PROJ.4 shared files: (autodetected)  Linking to sp version: 1.2-5   > ogrDrivers()              name                                                   long_name 1      AeronavFAA                                                 Aeronav FAA 2      AmigoCloud                                                  AmigoCloud 3          ARCGEN                                           Arc/Info Generate 4          AVCBin                                    Arc/Info Binary Coverage 5          AVCE00                               Arc/Info E00 (ASCII) Coverage 6             BNA                                                   Atlas BNA 7           Carto                                                       Carto 8        Cloudant                                          Cloudant / CouchDB 9         CouchDB                                          CouchDB / GeoCouch 10            CSV                                Comma Separated Value (.csv) 11            CSW                      OGC CSW (Catalog  Service for the Web) 12            DGN                                            Microstation DGN 13            DXF                                                 AutoCAD DXF 14         EDIGEO                               French EDIGEO exchange format 15  ElasticSearch                                              Elastic Search 16 ESRI Shapefile                                              ESRI Shapefile 17     Geoconcept                                                  Geoconcept 18        GeoJSON                                                     GeoJSON 19       Geomedia                                               Geomedia .mdb 20         GeoRSS                                                      GeoRSS 21            GFT                                        Google Fusion Tables 22            GML                             Geography Markup Language (GML) 23           GPKG                                                  GeoPackage 24       GPSBabel                                                    GPSBabel 25  GPSTrackMaker                                               GPSTrackMaker 26            GPX                                                         GPX 27            HTF                                Hydrographic Transfer Vector 28           HTTP                                       HTTP Fetching Wrapper 29         Idrisi                                        Idrisi Vector (.vct) 30     Interlis 1                                                  Interlis 1 31     Interlis 2                                                  Interlis 2 32            JML                                                OpenJUMP JML 33    JP2OpenJPEG                  JPEG-2000 driver based on OpenJPEG library 34       JPEG2000 JPEG-2000 part 1 (ISO/IEC 15444-1), based on Jasper library 35            KML                               Keyhole Markup Language (KML) 36         LIBKML                            Keyhole Markup Language (LIBKML) 37   MapInfo File                                                MapInfo File 38         Memory                                                      Memory 39   MSSQLSpatial                       Microsoft SQL Server Spatial Database 40          MySQL                                                       MySQL 41            NAS                                                 NAS - ALKIS 42         netCDF                                  Network Common Data Format 43           ODBC                                                        ODBC 44            ODS        Open Document/ LibreOffice / OpenOffice Spreadsheet 45       OGR_DODS                                                    OGR_DODS 46        OGR_GMT                                    GMT ASCII Vectors (.gmt) 47       OGR_OGDI                               OGDI Vectors (VPF, VMAP, DCW) 48        OGR_PDS                                Planetary Data Systems TABLE 49       OGR_SDTS                                                        SDTS 50        OGR_VRT                                    VRT - Virtual Datasource 51        OpenAir                                                     OpenAir 52    OpenFileGDB                                                ESRI FileGDB 53            OSM                                   OpenStreetMap XML and PBF 54         PCIDSK                                        PCIDSK Database File 55            PDF                                              Geospatial PDF 56         PGDUMP                                         PostgreSQL SQL dump 57           PGeo                                   ESRI Personal GeoDatabase 58       PLSCENES                                      Planet Labs Scenes API 59     PostgreSQL                                          PostgreSQL/PostGIS 60            REC                                               EPIInfo .REC 61            S57                                              IHO S-57 (ENC) 62       SEGUKOOA                                        SEG-P1 / UKOOA P1/90 63           SEGY                                                       SEG-Y 64        Selafin                                                     Selafin 65         SQLite                                         SQLite / Spatialite 66            SUA             Tim Newport-Peace's Special Use Airspace Format 67            SVG                                    Scalable Vector Graphics 68            SXF                                 Storage and eXchange Format 69          TIGER                                      U.S. Census TIGER/Line 70        UK .NTF                                                     UK .NTF 71            VDV                         VDV-451/VDV-452/INTREST Data Format 72            VFK                        Czech Cadastral Exchange Data Format 73           Walk                                                        Walk 74           WAsP                                            WAsP .map format 75            WFS                               OGC WFS (Web Feature Service) 76            XLS                                             MS Excel format 77           XLSX                              MS Office Open XML spreadsheet 78         XPlane                        X-Plane/Flightgear aeronautical data    write  copy isVector 1  FALSE FALSE     TRUE 2   TRUE FALSE     TRUE 3  FALSE FALSE     TRUE 4  FALSE FALSE     TRUE 5  FALSE FALSE     TRUE 6   TRUE FALSE     TRUE 7   TRUE FALSE     TRUE 8   TRUE FALSE     TRUE 9   TRUE FALSE     TRUE 10  TRUE FALSE     TRUE 11 FALSE FALSE     TRUE 12  TRUE FALSE     TRUE 13  TRUE FALSE     TRUE 14 FALSE FALSE     TRUE 15  TRUE FALSE     TRUE 16  TRUE FALSE     TRUE 17  TRUE FALSE     TRUE 18  TRUE FALSE     TRUE 19 FALSE FALSE     TRUE 20  TRUE FALSE     TRUE 21  TRUE FALSE     TRUE 22  TRUE FALSE     TRUE 23  TRUE  TRUE     TRUE 24  TRUE FALSE     TRUE 25  TRUE FALSE     TRUE 26  TRUE FALSE     TRUE 27 FALSE FALSE     TRUE 28 FALSE FALSE     TRUE 29 FALSE FALSE     TRUE 30  TRUE FALSE     TRUE 31  TRUE FALSE     TRUE 32  TRUE FALSE     TRUE 33 FALSE  TRUE     TRUE 34 FALSE  TRUE     TRUE 35  TRUE FALSE     TRUE 36  TRUE FALSE     TRUE 37  TRUE FALSE     TRUE 38  TRUE FALSE     TRUE 39  TRUE FALSE     TRUE 40  TRUE FALSE     TRUE 41 FALSE FALSE     TRUE 42  TRUE  TRUE     TRUE 43  TRUE FALSE     TRUE 44  TRUE FALSE     TRUE 45 FALSE FALSE     TRUE 46  TRUE FALSE     TRUE 47 FALSE FALSE     TRUE 48 FALSE FALSE     TRUE 49 FALSE FALSE     TRUE 50 FALSE FALSE     TRUE 51 FALSE FALSE     TRUE 52 FALSE FALSE     TRUE 53 FALSE FALSE     TRUE 54  TRUE FALSE     TRUE 55  TRUE  TRUE     TRUE 56  TRUE FALSE     TRUE 57 FALSE FALSE     TRUE 58 FALSE FALSE     TRUE 59  TRUE FALSE     TRUE 60 FALSE FALSE     TRUE 61  TRUE FALSE     TRUE 62 FALSE FALSE     TRUE 63 FALSE FALSE     TRUE 64  TRUE FALSE     TRUE 65  TRUE FALSE     TRUE 66 FALSE FALSE     TRUE 67 FALSE FALSE     TRUE 68 FALSE FALSE     TRUE 69  TRUE FALSE     TRUE 70 FALSE FALSE     TRUE 71  TRUE FALSE     TRUE 72 FALSE FALSE     TRUE 73 FALSE FALSE     TRUE 74  TRUE FALSE     TRUE 75 FALSE FALSE     TRUE 76 FALSE FALSE     TRUE 77  TRUE FALSE     TRUE 78 FALSE FALSE     TRUE ---- sorry, ok, and here my results (just forgot to import the library before) > library(rgdal) rgdal: version: 1.2-12, (SVN revision 681) Geospatial Data Abstraction Library extensions to R successfully loaded Loaded GDAL runtime: GDAL 2.2.0, released 2017/04/28 Path to GDAL shared files: C:/Program Files/R/R-3.4.0/library/rgdal/gdal Loaded PROJ.4 runtime: Rel. 4.9.3, 15 August 2016, [PJ_VERSION: 493] Path to PROJ.4 shared files: C:/Program Files/R/R-3.4.0/library/rgdal/proj Linking to sp version: 1.2-5 Warning message: package 'rgdal' was built under R version 3.4.2 > ogrDrivers() name long_name write 1 ARCGEN Arc/Info Generate FALSE 2 AVCBin Arc/Info Binary Coverage FALSE 3 AVCE00 Arc/Info E00 (ASCII) Coverage FALSE 4 AeronavFAA Aeronav FAA FALSE 5 AmigoCloud AmigoCloud TRUE 6 BNA Atlas BNA TRUE 7 CAD AutoCAD Driver FALSE 8 CSV Comma Separated Value (.csv) TRUE 9 CSW OGC CSW (Catalog Service for the Web) FALSE 10 Carto Carto TRUE 11 Cloudant Cloudant / CouchDB TRUE 12 CouchDB CouchDB / GeoCouch TRUE 13 DGN Microstation DGN TRUE 14 DXF AutoCAD DXF TRUE 15 EDIGEO French EDIGEO exchange format FALSE 16 ESRI Shapefile ESRI Shapefile TRUE 17 ElasticSearch Elastic Search TRUE 18 GFT Google Fusion Tables TRUE 19 GML Geography Markup Language (GML) TRUE
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20171010/560bc8b5/attachment-0001.html>
More information about the grass-stats mailing list
