[GRASS-stats] rgrass7 - SQLite and GML drivers not working for readVECT
Markus Metz markus.metz.giswork at gmail.com
Wed Oct 11 05:59:45 PDT 2017
Dear Roger,
On Wed, Oct 11, 2017 at 2:36 PM, Roger Bivand <Roger.Bivand at nhh.no> wrote:
> Dear Markus,
> I can't see how to get the same strings out without conditioning,
with
ogrDGRASSs <- gsub(" ", "_", trimws(sapply(strsplit(ogrDGRASS, " [(]"),
"[", 1)))
> because for v.in.ogr -f and GDAL >= 2.0, GRASS < 7.3 presents for example:
> GML (rw): GML
> SQLite (rw): SQLite
> ESRI Shapefile (rw): ESRI Shapefile
> GeoJSON (rw): GeoJSON
> (readOGR used the string following ":" )
The structure of the output of r.in.gdal -f and v.in.ogr -f is
 <short name> (<read/write flags>): <description>
readOGR must use the string preceding "(". Anything following ":" is a
description which can change any time. Before GDAL 2.0, there was nothing
else but the short name for OGR drivers, therefore the short name was used
as description.
> and >= 7.3:
> GML (rw+): Geography Markup Language (GML)
> SQLite (rw+): SQLite / Spatialite
> ESRI Shapefile (rw+): ESRI Shapefile
> GeoJSON (rw+): GeoJSON
> where the string after ":" is different.
the string before the read/write flags, i.e. before "(" is identical.
> If we can depend on all GRASS < 7.3 having the same short name position,
yes, I could avoid conditioning by changing the string processing to suit
>= 7.3 and apply it to all previous; I chose not to modify the string
processing for < 7.3 to avoid any problems I can't readily check.
For all versions of GRASS 7 and all versions of GDAL, the short name
position has been and continues to be the first position. For v.in.ogr -f,
the short name may also appear after ":", but only if there is no long name.
Best regards,
Markus
> Best wishes,
> Roger
> On Wed, 11 Oct 2017, Markus Metz wrote:
>> Dear Roger,
>> On Wed, Oct 11, 2017 at 1:41 PM, Roger Bivand <Roger.Bivand at nhh.no>
wrote:
>>> New version submitted to CRAN; until then:
>>> install.packages("rgrass7", repos="http://R-Forge.R-project.org")
>>> should pick up the latest version; #3425 closed. Please report back
>> whether this works ... (conditioning on GRASS version to create
comparable
>> driver name strings).
>> I don't think there is a need to condition on the GRASS version, see my
>> suggestion in #3425
>> Markus M
>>> Roger
>>> On Wed, 11 Oct 2017, Roger Bivand wrote:
>>>> Thanks for trying to contribute. The GH site is not the rgrass7
>> development site - that is SVN on R-forge (GH is a very preliminary trial
>> site for using sf vector representation in R, and maybe raster raster
>> representation (or forthcoming stars), instead of sp classes).
>>>> GRAS 7.2.2 works OK with the current logic checks; I can reproduce the
>> issue in 7.3 (latest); there is a change in vector/v.in.ogr/main.c
>> returning the DriverLongName for GDAL >= 2.0; in GRASS 7.2.2, there is no
>> such change. Could the GRASS developer responsible for this obvious
>> regression provide an additional flag in v.in.ogr (and v.external,
>> v.out.ogr) to permit backwards compatibility? See line 387, needs to
change
>>>> #if GDAL_VERSION_NUM >= 2000000
>>>> to add a !backwards_compatible test too.
>>>> I'll hold off trying to fix this in rgrass7 because it is a regression.
>> I can add the backwards_compatibility=TRUE flag to readVECT() once it is
>> exposed.
>>>> This is:
>>>> https://trac.osgeo.org/grass/ticket/3425
>>>> Roger
>>>> On Tue, 10 Oct 2017, Ahmadou Dicko wrote:
>>>>> In the readVECT function, internally v.in.ogr is used to list the
>> supported
>>>>> vector format and it is compared the format available using rgdal (or
>> sf).
>>>>> However, using v.external instead of v.in.ogr fix this single problem
>>>>> because of the way the output is different (in form).
>>>>> For example, if you use v.in.ogr you will have to compare
>>>> SQLite_/_Spatialite
>>>>> (GRASS) to SQLite (R) and they are not the same.
>>>>> I tried to send a PR, let me know if it works
>>>>> https://github.com/rsbivand/rgrass7/pull/1
>>>>> Best,
>>>>> On Tue, Oct 10, 2017 at 9:29 PM, Helmut Kudrnovsky <hellik at web.de>
>> wrote:
>>>>>>> Gesendet: Dienstag, 10. Oktober 2017 um 23:24 Uhr
>>>>>>> Von: "Ahmadou Dicko" <dicko.ahmadou at gmail.com>
>>>>>>> An: "Helmut Kudrnovsky" <hellik at web.de>
>>>>>>> Cc: "Roger Bivand" <Roger.Bivand at nhh.no>, "
grass-stats at lists.osgeo.org"
>>>>>> grass-stats at lists.osgeo.org>
>>>>>>> Betreff: Re: [GRASS-stats] rgrass7 - SQLite and GML drivers not
>> working
>>>>>> for readVECT
>>>>>>> Hi everyone,
>>>>>>> I think that using v.external -f (instead of v.in.ogr -f) can fix
this
>>>>>> issue (didn't try yet)
>>>>>>> execGRASS("v.external", flags = "f", intern = TRUE)
>>>>>>> [1] "ARCGEN"         "AVCBin"         "AVCE00"
>>>>>>> [4] "AeronavFAA"     "AmigoCloud"     "BNA"
>>>>>>> [7] "CAD"            "CSV"            "CSW"
>>>>>>> [10] "Carto"          "Cloudant"       "CouchDB"
>>>>>>> [13] "DGN"            "DXF"            "EDIGEO"
>>>>>>> [16] "ESRI_Shapefile" "ElasticSearch"  "GFT"
>>>>>>> [19] "GML"            "GPKG"           "GPSBabel"
>>>>>>> [22] "GPSTrackMaker"  "GPX"            "GeoJSON"
>>>>>>> [25] "GeoRSS"         "Geoconcept"     "Geomedia"
>>>>>>> [28] "HTF"            "HTTP"           "Idrisi"
>>>>>>> [31] "JML"            "JPEG2000"       "KML"
>>>>>>> [34] "MSSQLSpatial"   "MapInfo_File"   "Memory"
>>>>>>> [37] "MySQL"          "ODBC"           "ODS"
>>>>>>> [40] "OGR_GMT"        "OGR_GRASS"      "OGR_PDS"
>>>>>>> [43] "OGR_SDTS"       "OGR_VRT"        "OSM"
>>>>>>> [46] "OpenAir"        "OpenFileGDB"    "PCIDSK"
>>>>>>> [49] "PDF"            "PGDUMP"         "PGeo"
>>>>>>> [52] "PLSCENES"       "PostgreSQL"     "REC"
>>>>>> in a quick check, there is no difference in available formats.
>>> Roger Bivand
>>> Department of Economics, Norwegian School of Economics,
>>> Helleveien 30, N-5045 Bergen, Norway.
>>> voice: +47 55 95 93 55; e-mail: Roger.Bivand at nhh.no
>>> Editor-in-Chief of The R Journal,
https://journal.r-project.org/index.html
>>> http://orcid.org/0000-0003-2392-6140
>>> https://scholar.google.no/citations?user=AWeghB0AAAAJ&hl=en
>>> grass-stats mailing list
>>> https://lists.osgeo.org/mailman/listinfo/grass-stats
> Roger Bivand
> Editor-in-Chief of The R Journal, https://journal.r-project.org/index.html
URL: <http://lists.osgeo.org/pipermail/grass-stats/attachments/20171011/0e2bf285/attachment-0001.html>
More information about the grass-stats mailing list
