[GRASS translations] translate d.m
Tue Oct 26 21:55:08 EDT 2004
Stephan Holl wrote:
> is there an option to translate the GUI (d.m) as well with the
> *.po-Files?
No. Tcl doesn't have a gettext binding. There is the msgcat package,
which performs a similar task; lib/gtcltk/gmsg.tcl provides an
interface to it.
However, that isn't used at present in the tcltkgrass/d.m code, so if
you want to translate the UI, you will have to msgcat-ize the code
first. OTOH, lib/init/gis_set.tcl does use it, so you can use that as
an example.
More information about the grass-translations mailing list
