[GRASS-translations] incorrect refs?
Martin Landa landa.martin at gmail.com
Sat Aug 2 14:06:00 EDT 2008
2008/8/2 Maxim Dubinin <sim at gis-lab.info>:
> It seems that some of the references to the code are incorrect, here
> is an example from grassmods_ru.po:
>> #: ../raster/r.cost/main.c:275 ../raster/r.walk/main.c:392
>> msgid "Input null cell will be retained into output map"
>> msgstr ""
> If I look this code up in grass-6.3.0, first ref is this:
>>G_fatal_error(_("No start points"));
> and second is a blank line. I.e. links are wrong?
take a look at locale/README file.
In locale directory run first
make pot
make update-po
to update PO files.
Good luck, мартин
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
More information about the grass-translations mailing list
