[GRASS-translations] incorrect refs?
Martin Landa landa.martin at gmail.com
Sat Aug 2 15:17:08 EDT 2008
2008/8/2 Maxim Dubinin <sim at gis-lab.info>:
> We took source *_ru.po files from here:
> http://trac.osgeo.org/grass/browser/grass/trunk/locale/po
> where it says somewhere that the file were updated with the current
> code.
> the code I used to link was taken from here
> http://grass.osgeo.org/grass63/source/grass-6.3.0.tar.gz
SVN trunk is not corresponding to grass-6.3.0.tar.gz, its grass7 code
(still very similar to grass6 code-base, but it will change). If you
used po file from trunk you should checkout svn trunk then, see
http://trac.osgeo.org/grass/wiki/DownloadSource
Martin
Martin Landa <landa.martin gmail.com> * http://gama.fsv.cvut.cz/~landa *
More information about the grass-translations mailing list
