[GRASS-translations] commented lines with no refs
Wed Aug 6 21:16:12 EDT 2008
Maxim Dubinin wrote:
> probably another really simple question. I've considerable amount of
> commented lines without code references in the end of my POs (for example grasslibs_ru.po, last svn).
> #, fuzzy
> #~ msgid "Can't open directory %s"
> #~ msgstr "вектор  "
> Should I translate them? What are they for anyway?
AFAICT, messages marked #~ are "obsolete"; the help for the msgattrib
program says:
`--no-obsolete'
     Remove obsolete #~ messages.
`--only-obsolete'
     Keep obsolete #~ messages, remove all other messages.
I can't find that particular string anywhere in the source code, so it
appears to be a translation of a string which no longer appears in the
source code.
More information about the grass-translations mailing list
