[GRASS-translations] Re: grass-translations Digest, Vol 32, Issue 4
Nikos Alexandris nikos.alexandris at felis.uni-freiburg.de
Fri Sep 25 08:29:18 EDT 2009
Nikos:
> > > Maybe it is worth having a look at transifex [/].
> > > [/] http://www.transifex.net/
Markus N:
> > What is their license policy? GPL compliant? No shift of ownership?
> > This was the problem for years with launchpad rosetta, later they
> > changed their license model.
Nikos:
> In fact, if I am not doing a big mistake, it is a GPL-ed open source
> piece of software. The (attached) file "LICENSING" is to be found along
> with the source code of transifex [3].
Indeed, it is GPL (I got an additional reply from a dev of Transifex).
See also [4]. Also, according to the dev the problem you describe above
(wrt to rosetta) does not exist in Transifex.
I am just forwarding this information for your interest,
Nikos
> More about the tool	 [1][2]
> [1] http://www.transifex.net/about/
> [2] http://www.transifex.net/faq/
> [3] http://transifex.org/files/
[4] http://code.transifex.org/mainline/file/tip/LICENSE
More information about the grass-translations mailing list
