[GRASS-translations] RE: Continue the translation of grasswxpy_zh.po.
Markus Neteler neteler at osgeo.org
Sat Oct 30 12:24:26 EDT 2010
On Fri, Oct 29, 2010 at 4:25 AM, Shulin Yang <shulin at purdue.edu> wrote:
> Thank the team, you guys are so nice.
> I do have question now.  I got a Poedit error "msgfmt: found 4 fatal
> errors" now, and the detail is as:
> /home/shulin/Downloads/grass-translation/grasswxpy_zh.po:183: 'msgstr'
> is not a valid Python format string, unlike 'msgid'. Reason: In the
> directive number 1, the character '>' is not a valid conversion
> specifier.
> /home/shulin/Downloads/grass-translation/grasswxpy_zh.po:10197: number
> of format specifications in 'msgid' and 'msgstr' does not match
> /home/shulin/Downloads/grass-translation/grasswxpy_zh.po:10221:
> 'msgstr' is not a valid Python format string, unlike 'msgid'. Reason:
> In the directive number 1, the character ''' is not a valid conversion
> specifier.
> /home/shulin/Downloads/grass-translation/grasswxpy_zh.po:10231:
> specifier.
> msgfmt: found 4 fatal errors
> I believe this happened after I tried to translate this message "Enter
> parameters for '", I think it is the single apostrophe brought the
> trouble, but it did not happen before I reached the message, so I am
> very sure.  Please help me out, I tried to attach the po file in my
> email, but it out-reached the limit.  Is there any server I can load
> it for you?  Thanks
Please send it to me, I can take a look.
Markus
More information about the grass-translations mailing list
