[GRASS-translations] Translation missing of a expression:
Jenny Turner jennyturner1980 at gmail.com
Wed Jun 8 04:29:44 EDT 2011
Hello markus
Thanks. Just to better understand that: You will add it to grassmods or
grasslibs po fgile?
Thanks
On Mon, Jun 6, 2011 at 11:16 PM, Markus Neteler <neteler at osgeo.org> wrote:
> On Mon, Jun 6, 2011 at 1:31 PM, Jenny Turner <jennyturner1980 at gmail.com>
> wrote:
> > Greetings
> > I realized that this expression (quite common in Windows when running
> > g.mapset) :
> > Attention!
> > Locking is not supported on Windows!
> > Your shell continues to use the history for the old mapset
> > But there is no language with this translation. Can it be translated? If
> > yes, in which file shall it be added?
> You mean this message?
> ./lib/init/lock.c:    G_warning("Concurrent mapset locking is not
> supported on Windows");
> It was not indexed for translation, now it is. But it will only be
> translatable
> when I redo the .po files (not tonight but asap...).
> Markus
URL: http://lists.osgeo.org/pipermail/grass-translations/attachments/20110608/482ceaa6/attachment.html
More information about the grass-translations mailing list
