[GRASS-translations] Translation of messages and errors in Scripts
Thu May 19 11:59:18 EDT 2011
Monica Buescu wrote:
> And how about 6.4.0/1/2 ? It means that they are not scanned so I cannot
> translate them?
The 6.x build system doesn't support Python scripts, and no-one has
looked into localising shell scripts.
> In my case I'm using Python scripts runned from Sh.exe (in Windows)
> I'm willing do add by hand the input messages and the output I just need to
> know where to add them? grasslibs?
For now, you will need to use grasslibs, as that's what the _()
function installed by the grass.script module is set up to use.
More information about the grass-translations mailing list
