m.dem.extract
FINNEYB at AXE.HUMBOLDT.EDU FINNEYB at AXE.HUMBOLDT.EDU
Mon Aug 17 13:25:00 EDT 1992
Since you are having exactly the same problem I had with m.dem.extract, I
suspect that it is a program error.  What I did was to read the first two
files, then move the tape forward to the third file, and run the program
again.  When I got done, I had two dem cell files that I put together into
one.
Brad Finney
Humboldt State University
