Uncompressing a raster file
W. Fredrick Limp fred at spock.uark.edu
Wed Aug 19 08:02:03 EDT 1992
You probably will want to use r.stats... if you need one value
per line or r.out.ascii if you need a matrix..
both of these "convert" GRASS raster maps to ascii data
> I would like to use a raster map as input to another program that is
> not a part of GRASS.  However, the file is compressed.  I have tried unix
> uncompress without success and changing hte header file to try to
> force the file to uncompress.
> So does anyone know how to uncompress a raster file?
> thanks
> edwin at hwr.arizona.edu
W. Fredrick Limp,   Director                     FAX: (501) 575-3846
CAST, Center for Advanced Spatial Technologies   TEL: (501) 575-6159
12 Ozark Hall, University of Arkansas
Fayetteville AR 72701                             fred at kirk.uark.edu
