d.mon - program
James A. Farley jim at moray.uark.edu
Mon Dec 7 14:58:23 EST 1992
> Hello ,
> I did a installation of grass4.0 on Sun IPX machine - & have no problems.
> The problem is comming when starting d.mon program - there is no monitor
> on the list and what I should write for graphic monitor name ?????
> I found a catalogue MONITOR - it is empty ! :-o .
> Can anybody help me - maybe it is not a difficult problem.
> Thanks in advance
> Peter Sincak - Technical University of Kosice - Slovakia
Check the monitorcap file is GISBASE/src/etc. You need to uncomment the lines
corresponding to the monitors you wish to be able to access.
James A. Farley 	Technical Director, CAST/NCRI-SW
			12 Ozark Hall, Univ. of Arkansas
jim at moray.uark.edu	Fayetteville, AR  72701
Voice: (501) 575-6159	FAX  : (501) 575-3846
