Graphics Fonts
Bill Dailey 490-8324 (303) dailey at gpsrv1.gpsr.colostate.edu
Fri Dec 11 11:55:58 EST 1992
>>     Now when I use d.mon program is possible to see my configuration
>>     station (option 3) in the list, but the program fail when i try
>>     to use option 1 answering :
>>     " Graphics driver [x0] started "
>>     " Graph_SetX: display iclv3a:0.0 doesn't know font 9x15"
>>     Note that this error appear only on DECstation 5000/200, DECstation
>>     5000/125 and VAXstation 3100; while, if i start grass, from a HP
>>     APOLLO 700 it run properly.
I was having the same problem some time ago, on our VAXstations,
so I downloaded the new XDRIVER from moon and make the following modification.
in the grass directory:  src/display/devices/XDRIVER/XDRIVER
the file named:          Graph_Set.c
#define WIN_NAME   "GRASS 4.0"
#define BORDER  3
#define FONT "9x15"
    changed to
#define FONT "fixed"
William J. Dailey, GPSR Systems Analyst
USDA-ARS-NPA
Great Plains Systems Res.      TEL: 303-490-8324
P.O. Box E                     FAX: 303-490-8310
303 South Howes  Rm. 227       FTS2000:  A03RLGPSR
Fort Collins, CO  80522        INTERNET: dailey at gpsrv1.gpsr.colostate.edu
