compilation errors
Chris Skelly chris at mqatmos.cic.mq.edu.au
Tue Feb 25 17:09:19 EST 1992
Wow...is this a well monitored list or what! I thought you guys up-top
would be sleeping!
Regarding my previous compilation error message....thanks to
>    __                   __
>   /  )      /          /  )     Research Specialist
>  /   / _   /_  _      /__/      Ctr for Advanced Spatial Technologies
>  (__/_(_)_/ /_/ )_   /   _      National Ctr for Resource Innovations
>    /                            12 Ozark Hall, Univ. of Arkansas
>   /                             Fayetteville, AR  72701
>John E. Parks                    phone: (501) 575-6159
>[john at tang.uark.edu] Internet    or: (501) 575-4575
with the correct advice:
>the error messages indicate that your grass
>  library files are out of date with regard to your system "files".
>  Get a man on ranlib and then run it on the appropriate grass libraries
>  and I think it might correct this error.
Time elapased between when I mailed this group and the time I had corrected
the error = 12 min!!!!  Not too shabby considering the distance!
Thanks John!
Exactly what I did was the following:
              cd /.../.../src/libes/LIB
              ranlib -t *
recompiled with no problems.  If however, someone in the know would like
to explain WHAT I did...I know I'd be interested.
cheers,
chris
