p.map portability
Ronald E. Thomas ront at niwot.CFNR.ColoState.EDU
Thu Jul 16 09:43:46 EDT 1992
In reply to  allan at oregon.uoregon.edu;
I have had success using the pbmplus tools (scr.alpha) in converting ppm to pcx
format - which I then could import into Wordperfect.  Use the p.select "ppm"
option, create your p.map image; the file paint.ppm will be deposited in your
home directory.  Then use ppmtopcx to convert.
Hope this helps.
                                Ronald Thomas
                                 (ront at niwot.cfnr.colostate.edu)
                                  Rocky Mountain National Park
                                   Estes Park, CO
