P.MAP legend placement
Cliff Behrens CUSGCAB at MVS.OAC.UCLA.EDU
Fri Jul 24 12:13:00 EDT 1992
Martijn,
I was having a similar (perhaps, the same) problem.  I have a classified
satellite image and I need to generate a black-and-white map for
publication.  I defined and set patterns and set colors to black and
white.  The black-and-white map is generated just fine, with all the
correct patterns.  But, I don't get a legend out along with the map.
Are you at least producing a legend only in the wrong location?
