s.surf.idw
Chris Skelly chris at mqatmos.cic.mq.edu.au
Tue Mar 24 11:12:53 EST 1992
> The continue stmt in question is in a loop. It prevents the code which folows
> from being executed. I could have used and if-else, but I prefer this
> semantic when I can use it.
> Michael
but the "continue;" is in an "if" statement not a loop...the interpolation
routines are outside this "if" statement so doesn't the continue just
jump out of the if and do the interpolation?  I'm not myself if this is
a serious question, because I have used s.surf.idw and it works...unless
there are actually values under the mask...I have never checked...
chris
|\/\/\/|                             Chris Skelly
|      |                             School of Earth Sciences
|      |   High expolsives and       Macquarie University
|  (o)(o)   school do NOT mix.       North Ryde, 2109, NSW, OZ
C       _)                           Tel: 612-805-8433
 |  ,___|                            Fax: 612-805-8428
 |    /  chris at mqclimat.cic.mq.edu.au
