v.out.arc
Lars Schylberg larss at fmi.kth.se
Mon Nov 2 02:24:31 EST 1992
Yes !
I have used it successfully.  The are only two tricky things about using it.
1. The ungenerate files have to be placed under the directory
   "$LOCATION/arc/"
2. Sometimes the hint about which id-column you should use is wrong if you
   used the program interactively.  Examine the txt file yourself first
   to be sure which id-column to use,
Lars
Lars Schylberg                    Email: larss at fmi.kth.se
Department of Photogrammetry
Royal Institute of Technology     Tel.   +46 8 790 86 33
S-100 44  STOCKHOLM, SWEDEN       Fax.   +46 8 790 66 10
