v.in.ascii
BRYCE at net2.eos.uoguelph.ca BRYCE at net2.eos.uoguelph.ca
Thu Nov 12 12:25:21 EST 1992
on using v.i.ascii on an ARC-INFO stream file, the warning "failed to
attach attribute to arc" came up several times. the resulting raster
map created with v.to.rast showed a number of rivers with mising
sections. is there a method to overcome this loss of data?
