starting up with RIM
Simon Cox simon at cerberus.earth.monash.edu.au
Thu Oct 1 21:11:41 EDT 1992
I am having trouble getting started with RIM and s.db.rim
I have edited the following file as a template for .make:
> Foliation Orientation Data
> Site Code: ~sSite_Code~~~~~~            Location: ~yNorth~~
~xEast~~~
> Date surveyed: ~tSurvey_Date~~~~        Date entered:
~tEntry_Date~~~~~
> Lithology:     ~tLith1~~~~~~~~~~~~~~~~~~~~~~~~~~
> Structure:     ~tStruct1~~~~~~~~~~~~~~~~~~~~~~~~
> Comment:       ~tComment1~~~~~~~~~~~~~~~~~~~~~~~
> Orientation:  ~fDip_Direction~   ~fDip~~~~~~~~~~~~
I have tried "making" the database with this form two ways:
using the
command line s.db.rim .make command, and typing it in - the
response is as
follows:
> Form Definition Accepted.
> Building the RIM database in directory
/home/cerberus/u/simon/grass/rob_scott/> simon/rim/sites
> sh: Comment1: not found
> Database is now 'made'.
> The database fol has 0 records.
Note the problem with sh trying to interpret "Comment1".
.table  gives
> The number of rows reported below may have changed.
>       Database : fol                read password : none
last mod : 10/01/92
>          Table : fieldnames       modify password : none
>   Name              type      length     format     key
> No columns
last mod : 10/01/92>          Table : screenlayout     modify
password : none
> No columns
last mod : 10/01/92
>          Table : data             modify password : none
> No columns
Now I am worried - apparently this database has no structure.
Then, when I try to make an entry using .add I get
> WARNING: Site number (1) duplicated one in the database, not
added.
I have also tried loading sites from a site list, from a file,
etc etc
and every time it claims that, although there are 0 records in
the
database, the new site numbers duplicate older ones ...
I have tried every way into s.db.rim that I can find, and the
symptoms
are always similar.  Can anyone give me a quick diagnosis???  Is
there a
sample RIM/GRASS database to test out installation with??
Many thanks in advance.
Simon Cox
__________________________________________________________________
				Dr Simon Cox
         __  L
      ,~'  L_|\            	Department of Earth Sciences
   ,-'         \         	Monash University
   (            \		Clayton  Vic  3168  Australia
   \    ___     /
    L,~'   "\_x/		Phone +61 (3) 565 5762
              u   		Fax   +61 (3) 565 5062
     Bouquets gratefully accepted, brickbats returned to sender
