starting up with RIM
Susan Stitt nps!susan
Thu Oct 1 10:33:00 EDT 1992
In reply to:
>I am having trouble getting started with RIM and s.db.rim
>I have edited the following file as a template for .make:
>> Foliation Orientation Data
>> Site Code: ~sSite_Code~~~~~~            Location: ~yNorth~~
>~xEast~~~
>> Date surveyed: ~tSurvey_Date~~~~        Date entered:
>~tEntry_Date~~~~~
>> Lithology:     ~tLith1~~~~~~~~~~~~~~~~~~~~~~~~~~
>> Structure:     ~tStruct1~~~~~~~~~~~~~~~~~~~~~~~~
>> Comment:       ~tComment1~~~~~~~~~~~~~~~~~~~~~~~
>> Orientation:  ~fDip_Direction~   ~fDip~~~~~~~~~~~~
It looks as though a couple of lines are longer than 80 characters, if this
is true, then the make will fail...  When I used your screen file, editing it
to have 80 characters or less per line, I still had a comment such as:
>> sh: Comment1: not found
but using the .table command, I had columns listed:
Name              type      length     format     key
________________  ____ _____________ ___________  ___
Site_Code         int     1 words                 yes
East              doub    1 words    f11.2
North             doub    1 words    f11.2
Survey_date       text   17 chars
Current number of rows =   0
Try making sure your lines in the screen definition file are 80 characters
or less, and see if that makes any difference...
