HELP merge
martijn at scanner.frw.uva.nl martijn at scanner.frw.uva.nl
Wed Oct 21 11:46:14 EDT 1992
If you simply want to display both images at the same time, you can use the
d.his tool, using the coloured image as the hue (H) layer and the monochrome
image as the intensity (I) layer.
