small islands, how to eliminate?
Dave Gerdes dpgerdes at zorro.cecer.army.mil
Fri Oct 23 14:31:40 EDT 1992
> Date: Thu, 22 Oct 92 15:22:14 EDT
> From: mingham at grits.valdosta.peachnet.edu (mingham)
> Message-Id: <9210221922.AA03376 at grits.valdosta.peachnet.edu>
> Sender: lists-owner at max.cecer.army.mil
> Reply-To: grassu-list at max.cecer.army.mil
> Precedence: Bulk
> Subject: small islands, how to eliminate?
> Cc: rbrown at grits.valdosta.peachnet.edu
> Does anyone know a method to remove single pixel islands either in cell map or vector map
> ? I'm trying to export a grass file to arc.info and need fewer than 10,000
> polygons for it to work.
> Thanks,
> Mary Ingham
Well if the map is a binary 0/1 map, you can use  r.mfilter with the following
filter:
TITLE     delete islands for binary map
MATRIX    3
1 1 1
1 8 1
1 1 1
DIVISOR   17
TYPE      P
Caveat:  Does not get islands on edge of map for some reason.
I originally had the divisor as 9, but r.mfilter
rounds up instead of truncating so I had to compensate for it.
If you want to try it, this is my test input map that I used:
north: 10
south: 1
east: 10
west: 1
rows: 9
cols: 9
0 1 0 0 0 0 1 0 1
1 0 1 0 1 0 0 0 0
0 1 0 0 0 0 1 0 0
0 0 0 1 0 0 0 0 0
0 0 0 0 0 1 0 1 1
0 0 0 1 1 1 0 0 0
0 1 0 1 1 1 0 0 0
0 0 0 1 1 1 0 1 0
1 0 0 0 1 0 0 0 0
  Dave Gerdes
  US Army Construction Engineering Research Lab
  Spatial Analysis & Systems Team
  (217) 352-6511 x591
