Problem with v.in.arc
jimg at tembo.rutgers.edu jimg at tembo.rutgers.edu
Fri Sep 4 09:33:10 EDT 1992
> My colleague, Cindy Bell, is having a problem running v.in.arc.
> She goes through the procedure in ARC/INFO to create the lines_in,
> points_in, and text_in files then she fires up v.in.arc, puts in
> proper file names and parameter values and it blows up  with:
>    "could not locate the arc lines file"
> She's tried putting the lines_in file in different places thinking
> that the path name was causing the problem, but always with the
> same result.
> If anyone can shed light on how to fix this, we'd appreciate it.
I understand the reasons for having the v.in.arc command, but I've
always made arc coverages into DLG files for import into GRASS. The
advantage this has over v.in.arc is the ability to move attributes as
well as lines, points, etc. Maybe I'm missing something with the v.in.arc
command, and maybe someone else can shed some light on the subject.
What do people do when the v.in.arc command works ?? Do they then go in
and relabel everything ??
> You can reply here or to Cindy directly (cindy at geo.arc.nasa.gov).
> Thanks in advance!
> Susan Benjamin
> USGS NMD
Jim Gasprich				e-mail: jimg at ocean.rutgers.edu
Research & Support Slave		tel:    (908) 932-9631
Cook College Remote Sensing Center	fax:    (908) 932-8644
Rutgers University
PO Box 231
New Brunswick, NJ, O8903  	"Du bist mein Gweckman" - Anonymous Fascist
