John Parks tutorial printing problem
Will Mitchell csuucp!orion!wfm at uu3.psi.com
Fri Sep 11 09:41:21 EDT 1992
The painful answer is that you have to edit the PostScript.
It is looking for a font that you don't have on your printer.
Search for the font names in the code (Courier, Times-Roman,
etc) and just change them to something that you do have.  Be
careful--it is case-sensitive.
Often, there is a %%Resources line in a PS file that identifies
the fonts required.  This may be some help.
Good luck.
William Mitchell
wfm at comsearch.com
703-476-2627
