GRASS FTP site
Sincak
KUKO at CSPUNI12.BITNET
Thu Sep 17 08:29:43 EDT 1992
On Wed, 16 Sep 92 19:15:12 CET Martin Schroeder said:
>> There are a number of people having trouble getting to moon.cecer.army.mil.
>> We have moved moon from one machine to another. I suspect that host tables
>> stored to "old" IP address and need to be upgraded to the new IP
>> address. The new address is 129.229.20.254. You can try:
>> ftp 129.229.20.254
>> instead of
>> ftp moon.cecer.army.mil
>> to see if this is the case.
>Here are no problems getting to moon but using the 'dir' - command.
>Everytime following message appears:
> 230 Guest login ok, access restrictions apply.
> ftp> dir
> 200 PORT command successful.
> 425 Can't build data connection: Interrupted system service.
>Any solution ?
>Martin Schroeder
>l14 at aix320c.urz.uni-heidelberg.de
I am having exactly the same problem from 147.32.1.2 or 192.108.131.11
to touch grass server via 129.229.20.254.
Be so kind & help us -please .
Thanks
Peter Sincak , Kuko at CSPUNI12.bitnet
