r.in.erdas help
Xin Zhuang zhuang at access.digex.net
Wed Dec 1 18:20:17 EST 1993
I did "r.in.erdas erdas=tm083090.lan prefix=tm"
and took all 7 bands. I got tm.1 ... tm.7.
I run r.support to all of them and greated a group (tm90).
I was trying to run i.composite but failed. I was told
one of files was out of range which cannot be true.
I r.compress-ed tm.3 and wanted to look at it.
What I got were a whole bunch of vertical lines.
All the info in cellhd seem correct and match
the ERDAS file header (version 7.5).
Any hint would be appreciated.
--Xin
zhuang at access.digex.com
----- End Included Message -----
You might want to try i.in.erdas
it's in src.alpha/imagery
and works good with multi band images
_____________________________________________________________________
|  Tom Nelson                                                        |
|  Corps of Engineers                                                |
|  Fort Worth, Texas                                                 |
|  (817) 334-2095                                                    |
|  tom%alla@[155.84.92.2]                                            |
|____________________________________________________________________|
