Print maps using SPARCprinter
KLENKUS1 at VAXC.STEVENS-TECH.EDU KLENKUS1 at VAXC.STEVENS-TECH.EDU
Wed Dec 22 08:45:09 EST 1993
	First, set your printer up by using ps.select.  This will
set your printer correctly for ps.map.
	If your printer takes straight postscript then it will
just use the default printer.  When ps.map asks you for "
set printer and hit RETURN", just press return.  It should
start the process.
	I use ps.map to print to a postscript file and then
translate into a usable hp550c format.
	Hope this helps you.
Kym M. Lenkus
Davidson Laboratory
Hoboken, NJ  07030
