vectors
Bill Jackson jackson at lcta.cecer.army.mil
Fri Feb 5 10:41:29 EST 1993
You might try the v.patch command which should let you "combine"
numerous vector files together into a single layer. You may need to edit
the file in v.digit. Afterward, you should run v.support on the new map layer.
