CR/LF suggestion
Andrew Hertz hertz at geog.psu.edu
Wed Feb 10 21:31:11 EST 1993
Well I've never figured out how to strip off CR/LF characters
using sed or awk, however I was able to using dd - a file
conversion utility.  If you know the block size of the
records you can strip off the CR/LF by specifying an output
block size 1 byte smaller.  For example, the data general
machines used by the USFS typically use a block size of
1024 bytes with a CR/LF character appended.  To strip that
off, I used the following command where:
 if= the input file, of= the output file,
 ibs= input block size, obs= output block size
 cbs= conversion block size, conv= conversion type
dd if=in.dem of=out.dem ibs=1025 obs=1024 cbs=1024 conv=block
If you don't know the block size, you might be able to
deduce it using the command od - output dump utility.
For example:  od -a in.dem would output the dem file in.dem
a byte at a time interpreted as an ascii character - CR/LF
characters appear as nl (newline).  By comparing the byte
addresses where the nl characters appear the block size can
be determined (the addresses are in octal)
Good luck,
Andrew Hertz
