No subject
Net.Noise owner news at max.cecer.army.mil
Wed Feb 17 13:14:21 EST 1993
Newsgroups: info.grass.user
Path: zorro.cecer.army.mil!shapiro
From: shapiro at zorro.cecer.army.mil (Michael Shapiro)
Subject: Re: g.help problem
Message-ID: <C2Lunv.My at news.cecer.army.mil>
Sender: news at news.cecer.army.mil (Net.Noise owner)
Organization: US Army Corps of Engineers Construction Engineering Research Labs
References: <9302110503.AA04331 at brain.hsc.usc.edu>
Date: Wed, 17 Feb 1993 18:14:19 GMT
Lines: 50
In <9302110503.AA04331 at brain.hsc.usc.edu> pey at brain.hsc.usc.edu (Pey-Jiuan Lee) writes:
This is a tty interface problem, which surfaces from time to time
with programs like g.help that change the keyboard interface from
normal mode to single-character mode (possibly noecho as well). If
these programs don't exit properly, the keyboard interface is not reset.
In particular the normal Unix mode of operation is to convert the
RETURN key (ctl-M) to a LINEFEED (ctl-J). If you are seeing RETURN
not working but LINEFEED working, then you are seeing the effect
of the program not restting the interface back to its normal state
Depending on you system, you can reset the interface to a "normal" state
with the stty command, or the reset command, or the tput command:
	stty sane
	reset
	tput init
Of course you would have to type LINEFEED (ctl-J) instead of RETURN
	(ctl-J) stty sane (ctl-J)
Hopefully, this problem has been solved in 4.1. There maybe an update
on moon for g.help.
>We are having a problem with the g.help after we successfully (?) installed
>GRASS 4.0 on our SiliconGraphics IRIS-4D.
>By simply typing g.help on the command lind, we cannot use RETURN key to
>move the (*) to a topic/word.  However, this can be done by using Ctl-J key
>instead.  The worst thing is after we exit the g.help facility we still get
>the RETURN key function lost and it is equivalent to Ctl-M which results in
>the subsequent GRASS command unaccessible.
>Do you have any experience of solving this kind of problem or any suggestion
>on what installation procedure we might be wrong??
>Thanks in advance.
>Changyi Sun         USU Forest Resources, Logan UT 84322-5215
>	            Internet: csun at zircon.nr.usu.edu
>			      slt25 at cc.usu.edu
Michael Shapiro U.S. Army CERL
Environmental Division
