v.import
Bob Feeney feeney at vinny.cecer.army.mil
Fri Feb 26 17:24:37 EST 1993
Brian,
These errors are probably occuring because of the region.
The PNT_TO_AREA error occurs when an area is unable to be
closed.  This may be because a vector is getting cut out
during the import.  Try setting a larger region when you
import these.
I saw a message a while back about the matching error but
I can't remember what the cure was.  I've run into this on
my files and if the labels are the same, ie;
WARNING:  area 3959 label:  255317 matched another label: 255317
there seems to be no problem.  But if they are different, as in
your case I would be concerned.
Depending on the size of your file, you may want to try to locate
the areas in question, remove all labels from them in v.digit and
then relabel them - just a suggestion.
I'm not an expert on these problems but these are just some
techniques I've used.
Bob
FYI - feeney at vinny.cecer.army.mil
      (217) 373-4420 Ext. 320
