No subject
root at uknet.ac.uk root at uknet.ac.uk
Fri Jan 8 04:23:53 EST 1993
Sender: lists-owner at moon.cecer.army.mil.
Reply-To: grassu-list at moon.cecer.army.mil.
Precedence: Bulk
To: info-grass-user
Path: uknet!liv!wjones
Newsgroups: info.grass.user
Subject: Installing Grass 4.0 - Problems
Message-ID: <93008.091255WJONES at LIVERPOOL.AC.UK>
Date: Mon, 8 Jan 93 09:12:55 GMT 01:00:00 +0000 (GMT)
Organization: University of Liverpool
Lines: 31
I require some help with installing GRASS 4.0 on a UNIX based SUN system
at Liverpool University.
The version of SunOS used here is 4.1.2.DBE1.2
The problem is that I have installed GRASS and it works fine besides these
problems with the display.  The problems are:
1)  When screens similar to the start-up screen of GRASS are exited
    the display there after scrolls diagonally.  I have discovered that
    this is because of the absence of a carriage return charcter, <CR>, at
    the end of each line.
2)  When G.HELP is exited the terminal no longer echos characters back to
    the display and in some cases freezes the terminal by not allowing
    input at the keyboard.
I suspect both of these problems are concerned with the terminal configuration
here at Liverpool.
I would appreciate any help with this problem.
Yours in hope
Bill Jones
Computing Services Department
The University of Liverpool
P.O. Box 147
LIVERPOOL
U.K.
