attributes
Ronald E. Thomas ront at niwot.CFNR.ColoState.EDU
Fri Jan 22 10:23:39 EST 1993
Brian,
It sounds as if your DLG-3 file was unlabeled.  Attributes are the
points within a polygon where a number is attached, and it sounds as if you had
an "empty" dlg-3 file to start with.  Double-check your source and make sure
the file was labeled.  ( The category file (in dig_cats) is the file that gives
a text label to each discrete attribute number.)
   Ronald Thomas                         ^  ront at meeker.cfnr.colostate.edu
    Natural Resources Spec. (GIS)        ^
     Resources Management Division       ^   Phone: 303-586-3565  x285
      Rocky Mountain National Park       ^          700-323-7285  (FTS)
       Estes Park, CO  80517             ^
