Compiling 4.1
Jim Pirzyk pirzyk at cerl.cecer.army.mil
Fri Jun 25 09:39:23 EDT 1993
In info.grass.user you write:
>	I've taken the plunge and have started to
>install GRASS4.1 on our Sun Sparc 2 with OpenWindows2.0.
>Compilation stops with src.alpha/display/d.labels.  Here is
>the GISGEN output:
>rm -f OBJ/where.o
>cc -O  -I/usr/local/grass4.1/src/include  -c where.c
>"where.c", line 75: warning: statement not reached
>mv where.o OBJ/where.o
>rm -f OBJ/modify.o
>cc -O  -I/usr/local/grass4.1/src/include  -c modify.c
>	Any suggestions on where to start looking for
>the problem?
>	Thanks for any advice.
Did you solve your problem?  It seems from the output that you did not have an
error.  It should not have died from a warning.  I would not worry about the
warning message if the binaries are working alright.
- Jim
[Jim] pirzyk at uiuc.edu ------------------------------------------
TAC & GrassNet System Administrator, US Army Corps of Engineers
Construction Engineering Research Labs, Champaign IL USA
