METADATA script file
Michael Shapiro shapiro at zorro.cecer.army.mil
Wed Jun 30 13:03:31 EDT 1993
In info.grass.user you write:
>I have completed work on an in-depth script that facilitates the entry of
>metadata, and am seeking interested user's to test it out.  The metadata
>standards it uses are based on the suggested METADATA file forwarded to the
>grassu-list by USACERL a month or so ago.  Attempting to adopt GRASS
>standards, the metadata file is named the same as its data layer, and
>the files are stored at $LOCATION in a directory named "metadata".
>"r.meta" only uses the raster portion of the metadata list, the imagery
>fields will be included in a script I am developing called "i.meta".
>These scripts will have to be redone once (if) the national metadata standards
>come on line, and for the metadata file to become an integrated part of GRASS,
>the code for "g.remove", "g.rename", and "g.copy" will have to be modified
>so that these functions include the metadata file. I currently don't know how
>do this, but am looking into it.
For raster data, if you put the metadata under cell_misc/<map>/metadata
g.remove, g.rename, g.copy will automatically deal with this file as well.
U.S. Army CERL                (217) 373-7277
P.O. Box 9005
Champaign, Ill. 61826-9005
