installing xgrass from binaries
Andy Burnett burnett at zorro.cecer.army.mil
Wed Jun 30 14:04:28 EDT 1993
In info.grass.user you write:
>Is there a default location to put this file so that a
>new user can start up automatically?
  When xgrass starts up, it looks for xgrass-menu in $GISBASE/etc.  If
~/.xgrass-menu exists, it will read that file instead of the system default.
>Secondly, I found that xgrass was looking for the dialog-box descriptions
>in $GISBASE/etc/a.prog.xclip, whereas the file names distributed in
>the binaries were just $GISBASE/etc/a.prog
>Easily fixed by renaming the files, but was this necessary?  Or is there
>a single string in a file somewhere that I should have changed?
  There is no work around for this, as after the binary distributiion was
compiled, all the *.xclip file names were changed to omit the .xclip.
					&y
Andy Burnett                --  burnett at zorro.cecer.army.mil
US Army Corps of Engineers  --  Construction Engineering Research Lab
