sun4
    Cliff Behrens
    cliff at bellcore.com
    Thu Mar 11 10:47:35 EST 1993
Without the advantage of seeing the messages you are getting, there may be one
of two problems:
1)  you did not edit the lists/local file which tells the compiler which
     display device you are using, or
2)  you haven't a path to the X include files needed to compile those modules
    in the "display section" that require them.  See the comment lines in the
    following file:
  ../src/display/devices/XDRIVER/XDRIVER/Gmakefile
