point_layer in a dlg format
Daniel Rodriguez
danr at rsgis2.tamu.edu
Fri May 14 18:00:27 EDT 1993
Dear Grassuers:
I have a point layer which is in a dlg format created in ARC/INFO.
The file contains a point layer (labels) and county boundary which were
created in ARC/INFO with the command:
ARCDLG <in_cover> <out_dlg_file> {in_point_cover}.
When I convert the dlg file into a Grass4.0 vector file with the commandv.in.dlg, the boundary is the only cover created and not the 347 labels with
coverage. Should I use v.import ?
Is there a seperate command to bring in a point layer dlg coverage into
grass4.0.
Thank you,
Daniel H. Rodriguez
Texas A&M University
College Station, Texas 77845-2135
