Digitizer thru X-terminal???
Bill Miller bmiller at dg4600.swc.NoDak.edu
Wed May 26 13:40:00 EDT 1993
> Question: Can a digitizer be made to function through an X-Window
> display server runing on a PC ?
> INFO:  I am runing a Data General AViiON 4625 server with GRASS4.1beta
> (soon to be 4.1) on an ethernet with two PCs runing MS windows 3.1 and
> Control Data Vista-eXceed/W (for windows).  The total setup works fine,
> so far.  Now, I want to connect a digitizer into the system but would
> perfer to do so through the PCs network connection.  Has anyone
donethis
> before and have any info to support this function?
> Thanks.
> 	Bill Miller
> 	DataProcessing Coordinator
> 	701-224-4288 FAX 3696
>       bmiller at dg4600.swc.nodak.edu
>  --------End of Unsent Message
Bill M.
