d.mon - Problem
Malcolm Williamson malcolm at cast.uark.edu
Tue Nov 9 22:39:54 EST 1993
Kym Lenkus writes:
(lines deleted)
> 	I get the following errors after I type :
> 		d.mon
> 		1             for start graphics monitor
>             x0             for xdriver
> Graphics driver [x0] started
> ERROR: region for current mapset is not set
> 	   run "g.region"
> Problem selecting x0. will try once more.
First, set your region by typing "g.region rast=raster_layer_name" (try using
elevation.dem or equiv if you are in spearfish location). This will create
the $LOCATION/WIND file that Darrell mentioned. If this command works, and
d.mon still doesn't, than you have more serious problems!
Good luck!
Malcolm D. Williamson - Research Assistant       E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies      Telephone: (501) 575-6159
Ozark Rm. 12                                        Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
