r.drain command
Olga Waupotitsch olga at zorro.cecer.army.mil
Thu Sep 2 13:58:03 EDT 1993
In info.grass.user you write:
>1.I need coordinates be read of a file. How can I do?
>2. I need so many points can be input, but GUGS section say me "Currently, r.drain will not
>   actually provide output for more than one pair of input coordinates stated on the
>   command line".
>   How can I solve it? What about grass4.1 "r.drain" version?
>Thanks.
>   Antonio Munoz Rastrero
It is true that in 4.1 release d.drain did not accept more than one pair
of coordinates from command line or from file.
How ever I fixed it for the update number 1, so If you have installed
update 1, ignore what the manual says. Now you can provide the coordinates
in a raster file (as described in a manual) and give more that one pair
of coordinates on the command line.
Hope this helps!
Olga
