Problems with GRASS Shell in XGRASS
Malcolm Williamson
malcolm at cast.uark.edu
Thu Sep 9 10:43:08 EDT 1993
Terje,
This is just to let you know that you are not alone! The dependency of the
XGRASS GRASS Shell on the .grassrc file has been noted and complained about by
several others on this list. For the time being, the only solution that I know
of is to make sure that your .grassrc file agrees with the XGRASS session that
you are running.
Keep an eye on these lists; maybe a solution will be forthcoming.
Malcolm D. Williamson - Research Assistant E-mail: malcolm at cast.uark.edu
Center for Advanced Spatial Technologies Telephone: (501) 575-6159
Ozark Rm. 12 Fax: (501) 575-3846
University of Arkansas
Fayetteville, AR 72701
> I have imported the compiled version of XGRASS4.1 BETA on a SUN OS4
> computer.
> Some problems appears when I want to run GRASS Shell from the
> XGRASS-menu:
> 1 To use the GRASS Shell, the file .grassrc have to exist in my
> home directory. This is created only when running GRASS (not
> XGRASS).
> 2 When .grassrc was created it was possible to open a GRASS
> Shell in XGRASS for the Location and Mapset given by
> .grassrc. For any other Location and Mapset an error message
> was flashing over the shell-window that disappeared at once.
> 3 When I tried to start GRASS Shell with various Locations and
> Mapsets IT SUDDENLY STARTED TO WORK !!!
> But it ignores the Location and Mapset selected from XGRASS,
> and uses the Location and Mapset given by .grassrc.
> Is there anybody out there that can explain these problems?
> Terje
> Terje Midtboe
> Division of Surveying and Mapping Phone: +47 7 594583
> University of Trondheim Fax: +47 7 594621
> N-7034 TRONDHEIM E-mail: terjem at igf.unit.no
> NORWAY
