Covert GRASS file to GRID in ARC/INFO?
Anantha Prasad prasad at landcover.inhs.uiuc.edu
Fri Sep 10 10:20:18 EDT 1993
Hi Tong,
First convert grass map to ascii using r.out.ascii
Then change the header of the ascii file to the
format required by Arc/Info's asciigrid.
To get the format type "help asciigrid" at the
arc prompt...
This procedure converts grass to arc without any
problems...
Anantha Prasad
Univer. of Illinois,
Urbana
