need help with PS.MAP....
Craig Anderson caa at noaacrd.Colorado.EDU
Tue Sep 14 16:43:31 EDT 1993
Mary;
	Firstly, is your printer on a network?  And if so do you manually
send your output to the printer.  (this is my situation)
	Second, try playing with the location of the colortable as a
start, I have found that if the colortable is overlapping with the map
image because of placement, my printer experiences the same problem.  The
same is often true for text.
Craig
caa at noaacrd.colorado.edu
