SPANStoGRASS
Amy Keeley UNCA Contractor akeeley at ncdc.noaa.gov
Fri Apr 29 13:33:58 EDT 1994
	Hi. I'm attempting a data transfer from SPANS5.3 to
	GRASS4.1.  So far, I've exported a file from SPANS
	into the  ASCII DLG format.  After attempting to
	pull this into GRASS with v.import, I get a message
	that states, "Error reading DLG header."  Can anyone
	help me?
	NOTE:  The outputs from the SPANS are actually two
	files: filename.VEH and filename.VEC.  I'm assuming
	that the .VEH file is a header file and the .VEC file
	is the vector file.  Now, how do I combine the two
	of these so that v.import can read them both??
		Thanks in advance,
		Amy Keeley  akeeley at ncdc.noaa.gov
